Právě je ned říj 18, 2026 12:03 pm
[ Příspěvků: 7 ] |
tangoforce
Předmět příspěvku: HELP - Remote Locking Napsal: ned lis 30, 2008 2:11 pm |
Hi
Last night my remote control locking stopped working. The car does not respond to the key and will not lock or unlock.
I can still lock the car manually... I must use the central locking button, get out and then lock the driver door from outside using the key in the lock.
Any idea why my car won't lock or unlock by remote control?
Předmět příspěvku: Napsal: ned lis 30, 2008 5:21 pm |
battery in the key?
tangoforce
Předmět příspěvku: Napsal: ned lis 30, 2008 6:37 pm |
I've already tried spare batteries.
The red light on top of the steering column does not light up anymore which makes me think there is a hardware fault with the decoder.
I've tried to resynchronize the keys but the car does not respond to them at all during this procedure.
Předmět příspěvku: Napsal: ned lis 30, 2008 8:10 pm |
it can be decoder... go to Renault´s and they will do diagnostic..
tangoforce
Předmět příspěvku: Napsal: pon pro 01, 2008 1:58 am |
Renault in the United Kingdom are VERY expensive.
There customer service is terrible.
Předmět příspěvku: Napsal: pon pro 01, 2008 12:18 pm |
The same in CZ... :-( But it is very difficult to repair without diagnostics...
Předmět příspěvku: Napsal: pon pro 01, 2008 2:25 pm |
yes, here is it the same.... i go to renault only when i go to diagnostic, because it is only one option.... then you can repair the thing, because you know where is it bad...
or when you must buy some things
[ Příspěvků: 7 ] |
