Právě je ned říj 18, 2026 12:08 pm
[ Příspěvků: 8 ] |
tangoforce
Předmět příspěvku: Keys - How many can I use? Napsal: čtv srp 28, 2008 10:02 pm |
Hi
When I got my safrane it came with just 2 keys.
The driver seat has 3 memory buttons.
Can I use 3 keys with the safrane or will the car security not allow it?
Předmět příspěvku: Re: Keys - How many can I use? Napsal: čtv srp 28, 2008 10:30 pm |
tangoforce píše: Hi
Can I use 3 keys with the safrane or will the car security not allow it? i dont understand it... do you mean keys? or seat´s memory..? you can have perhaps infinite keys... and memory? you can have 3 memory like 3 buttons...
tangoforce
Předmět příspěvku: Napsal: čtv srp 28, 2008 10:45 pm |
Yes I mean keys. Can I use 3 keys with this car? Will the security allow 3 keys?
It seems silly to have 3 drivers but only 2 keys!
Předmět příspěvku: Napsal: čtv srp 28, 2008 10:50 pm |
tangoforce píše: Yes I mean keys. Can I use 3 keys with this car? Will the security allow 3 keys?
It seems silly to have 3 drivers but only 2 keys! ou yeah.. i understand..  so i think that you must only programing keys but you can have 9999999 keys.... because keys are all same... all keys are like the one, with the same code.
Předmět příspěvku: Napsal: pát srp 29, 2008 8:35 am |
You can lend your key to someone else, can't you? Or for example if your wife is driving she definitely has different seat and mirror adjustments but she can use your key.
From my point of view these are two different things which are not connected - the seat memories and the nr. of ignition keys.
tangoforce
Předmět příspěvku: Napsal: pát srp 29, 2008 9:59 am |
Yes I could lend the key but then it must be removed from my collection of keys and that can be awkward.
I was just asking because seeing as there are 3 memories it would make sense to have 3 keys for 3 drivers. After all there are memories for 3 drivers!
How can you not see this as being connected?
Předmět příspěvku: Napsal: ned srp 31, 2008 10:42 am |
tangoforce píše: Yes I could lend the key but then it must be removed from my collection of keys and that can be awkward.
the all 3 memories can use only one driver, for some people (like me) is good to change the position by long trip, sometimes is for me better one position, sometimes the other.. Safrane originally shoud have 2 keys... but you can buy so much copies of your key, how much you want.. but the memories and the keys have realy no connection
tangoforce
Předmět příspěvku: Napsal: ned zář 07, 2008 11:35 am |
Yes but how many keys will the car security system allow?
We have a megane and that will only allow the use of 2 keys.
[ Příspěvků: 8 ] |
